Results 1 to 10 of 19
    Sep 2010
    Absolute Best Low-Light/High ISO Camera Under $1000?
    Okay, so I've been digging through the web, looking at all manner of digital cameras, and I'm starting to lose my mind a bit. So I realized, I can basically consolidate my true needs down into a single question-
    What is the absolute best camera I can buy for low-light/high ISO image quality under $1000? No other features matter. SLR, point-and-shoot, micro 4/3, fixed lens, interchangeable lens, doesn't matter. All that matters is maximum quality (i.e. low noise) low-light images. Obviously a full-frame sensor is the best bet, but I've yet to find a full-frame camera anywhere near the $1000 mark, and it doesn't look like that's going to change anytime soon. So, what's the closest I can come to that kind of low-light performance around the $1000 price point?
    Anyone have any ideas?
    Thanks!
    (Oh, also, has to be digital- not interested in film.)
    Exeter, UK
    The Pentax K-x DSLR seems to be quite well regarded for low noise at high ISO. A good wide aperture lens will help, but that depends on what you're shooting.
    Without specifying what kind of lens you are looking for it's going to be hard to get a DSLR or EVIL camera recommendation that is complete. Lenses are going to play a significant part in the low-light picture. At that price range you may be looking at a 50mm 1.4 lens, but if you want some telephoto to go with your high ISO performance it will be disappointing.
    Sep 2010
    Ah yes, sorry I forgot to specify. I'll definitely be using a f/1.4 prime, or whatever the fastest lens I can find is. I'm not concerned with any type of zoom.
    Jan 2009
    Milwaukee, WI
    My best guess would be a Nikon D5000 with a 50mm f1/4. I am sure the Canon counterpart and the others have similar options/performance, but I am not all that knowledgeable in those areas.
    Sep 2010
    Okay so I have a D60 currently, with a Nikon f/1.8 prime. And the low light shots I get definitely aren't bad, but they're also nowhere near a 5D Mark II (not that I expect them to be). So question would be- would one of the higher-end APS-C DSLRs like the 7D or D7000 provide a noticeable improvement over the D60 in low-light, or are they all basically pretty similar until you make the jump to full-frame?
    Quote Originally Posted by blabus View Post
    There's been a big improvement in high-ISO performance since the sensor generation used in the D60. Going to the D5000 or Pentax K-x will provide a meaningful increase.
    If you're highly invested in Nikon accessories already, and/or you really like the system, I think saving up for the D7000 is almost a no-brainer.
    Otherwise, the Pentax K-x gives you the best bang for the buck right now (leaving room to spare under $1000 for both the camera + kit lens and the FA 50mm f/1.4). And the K-r looks interesting as a replacement when it hits the shelves later this month but it won't be as much of a bargain initially.
    Looking to buy a Pentax flash? Check out my Definitive Guide to Pentax P-TTL Flash Options.
    the d5000 is about 1 stop better than a d60. 7d is not under $1k.
    Hmmm I hadn't really compared the D5000 and K-x before now; I'd assumed they were basically the same since they use a very similar sensor. Looks like the K-x gains you about an additional stop over the D5000 (and saves you $200).
    Quote Originally Posted by mattdm View Post
    lol a stop better ? in your dreams.
