Results 1 to 10 of 16
    Mar 2008
    Los Angeles, CA
    Battery Charger Question: 120v or 100-240v?
    I'm about to ship my Nikon D40 from the States to Poland. Looking at the battery charger I see a big INPUT: 120v ~ 60Hz which would make it U.S. only. But then in a frame right below it states: Foreign input AC 100-240V 50/60hz.
    Does that mean this charger works from 100 to 240V or is it US only 120V? Wording of both right next to eachother is rather weird.
    A fast response would be greatly appreciated as I'm packing now. Thank you.
    Nikon D90, Nikkor 18-105mm f3.5-5.6 VR, Nikkor 50mm f1.8D, Nikkor 55-200mm f4-5.6 VR. Always looking for creative criticism.
    Panasonic Lumix DMC-ZS3 P&S.
    The Nikon battery chargers like the vast majority of switch mode power supplies these days will work on both 120V 60Hz and 220-240V 50Hz AC power supplies.
    All you will need is an adapter available from any airport or travel goods store that will convert your US wall plug to whatever wall plugs are used in Poland.
    Philadelphia
    I don't have a D40 or MH-23 so can't be totally definitve in reply, however every Nikon charger I have ever owned has been universal voltage...
    The MH-18 for my D300 is labelled in the same apparently contradictory way as yours - I suspect that perhaps the supplied power cable may only be rated for 120V... in real life (rather than potential product liability defense lawyers offices) mine worked fine with a plug adaptor with UK 240v power last summer.
    D300 | MB-D10
    18-105MM F/3.5-5.6G ED AF-S DX VR | 105mm f/1.8 AI-S | 70-300mm f/4.5-5.6G ED-IF AF-S VR | 80-200 f/2.8 | 50mm f1.4 | SB-900 | SB-600
    Mar 2008
    Los Angeles, CA
    Thank you. I already have the correct plugs so it should just work. The labeling threw me off a little as I'm used to the usual 100-240v on most power supplies.
    Germany
    Quote Originally Posted by britkev View Post
    Eh - no. Suitability of cables is not a matter of voltage, but of wattage. The more Watts you need, the thicker the cable diameter has to be. And regardless of the fact that a charger for a LiIon battery doesn't have that many Watts to begin with, doubling the voltage from the US 120V to the European 240V would cut the amperage in half to maintain the same wattage, so it doesn't make a difference for the cable.
    I don't think there are many chargers around these days that cannot handle the whole range of 110 - 240V.
    As a side note, when traveling to a country that uses different wall plugs than at home, remember to take a multi-outlet power strip along, then one single adaptor (US -> European or whatever) will be enough.
    Stefan Hundhammer
    Nikon D700, Sony R1, Sony T10
    Nikkors: 24-70 f/2.8 +++ 70-300 VR f/4.5-5.6 +++ 18-35 f/3.5-4.5
    +++ 20 f/2.8 +++ 24 f/2.8 +++ 35 f/2 +++ 50 f/1.8 +++ 85 f/1.8
    Sigma 150 Macro f/2.8 +++ Sigma TC 1.4 +++ Metz 54i
    http://www.flickr.com/photos/huha/
    Philadelphia
    Yeah, I'm familiar with Ohm's law, however the power cable supplied with the MH-18 in the US is clearly stamped 3A - 125V, so while no laws of physics are being violated it is easy to see why Nikon USA label their chargers in this way.
    D300 | MB-D10
    Photography seems to be the hobby for the scientifically literate
    My charger (used in Aust, bought in Japan, manufactured in Malaysia) doesn't have that first line but just says "AC100-240V 50-60Hz"
    How come you got the good one?
    My charger says made in China on the bottom!
    Guess it's just my camera is a year older since I assume you bought yours grey market like I did.
    Or did you get the Chinese charger because you bought the camera at a dinkie die Aussie shop for 50% more than I paid?
    Adelaide, Australia
    ouch......
    Nikon D7000 - Nikkor AF-S 70-200vrII f2.8 | Nikkor AF-S 105vr f2.8 Micro | Nikkor AF-S 16-85 | Nikkor AF-D 35mm f2 |Tamron SP 90mm f/2.8 Di Macro | SB-700 | SB-600
    Website
