Results 1 to 10 of 20
Thread: Lighting Help!
    Carlsbad CA
    Lighting Help!
    I've used lighting before but never set it up or bought it before.
    Im using a sony a350.
    I need two big lights for small weddings and cocerts.
    What do I need and recomendations?
    Its not going to be used everyday so it doesnt need to be amazing.
    any help is awesome
    sony A300
    tamron 17-50 2.8
    Sony SAL 11-18
    Sony 35 1.8
    Bay Area, California
    What exactly will you be using the lights for? Formal portraits? Help lighting the venue?
    R3G Media | Flickr
    Carlsbad CA
    Half for doing portraits, such as a band. Nothing in like super dark areas but just so I have eveyrthing to go.
    sony A300
    tamron 17-50 2.8
    Sony SAL 11-18
    Sony 35 1.8
    Have you considered using a hot shoe flash with a diffuser like the Sto-Fen Omnibounce? A lot of wedding photographer use that kinda setup in the reception and such.
    R3G Media | Flickr
    Recommendation: Get a solid book on lighting and get reading. Artificial lighting takes practice, practice ... yep, Carnegie Hall, here we come! If you can make it to one of the camera stores, like B&H or Calumet Photographic, these guys sell this gear for a living and can often advise you with direct questions and suggestions.
    Remember: inexperience can cost you money.
    shop lights in a soft box work as good as anything
    Mar 2009
    San Diego, CA
    Quote Originally Posted by SONYNUT View Post
    Yeh, but fitting the people into the soft box gets a bit tricky.
    Darin Wessel
    α 900
    Zooms: Tamron SP AF70-200mm f2.8 Di LD Macro; Sigma 28-90mm D macro, Konica-Minolta 18-70 f3.5-5.6
    Primes: Minolta 28mm f2.8; Sony 50mm f1.4
    Minolta RC-1000 remote commander
    Film:
    Calumet Cambo CC400 4x5 View Camera
    YashikaMat 6x6 TLR (other accessories)
    Minolta Maxxum 7000 w/ Minolta 35-80mm f/4-5.6 & Minolta 2800 flash
    Minolta Maxxum 5000i & Vivitar 728 AFM flash
    What's next???
    Carlsbad CA
    I just want someone to link me to something they recomend like a kit lol
    sony A300
    tamron 17-50 2.8
    Sony SAL 11-18
    Sony 35 1.8
    Lightbulb A kit to kick butt
    Wireless Strobes & Stands
    Background Kit
    This is my choice ... and basically what I have ... supplying my own wireless trigger signals (as it had not be invented back then)
    Still, I recommend reading about it, first.
    Background Kit
    for small weddings and concerts ? come on Don get real. lol
    brian you have 3 options.
    1. use a hotshoe mounted flash as reg suggested with a big diffuser.
    2. use the IR wireless trigger built into your sony dslr in which case you need 2 sony flash units that work in wireless mode, the sony guys can help you with that.
    3. the best option by far...use radio triggers. an option like cybersyncs is a good cheap reliable option. you would need 1xtransmitter and 2xreceivers, (1 for each flash). then you buy pretty much any older flash unit that has a PC sync port, (like the sb28's for example), which are pretty cheap.
    option 3 will set you back around $600-$700 i suppose.
