Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
  1. #21
    Frank, 3 EV is quite a big range and more than adequate for most (I almost said all) situations. Of course, you need to be aware of the overall lighting and use the VF (and AE Lock button) to isolate the appropriate area for metering excluding very bright or very dark areas which are not part of the subject. Apart from when using a Macro lens or Tubes, I really can't think of an occasion when 3 EV compensation was not sufficient.
  2. #22
    [QUOTE=Peekayoh;398058]Frank, 3 EV is quite a big range and more than adequate for most (I almost said all) situations. Of course, you need to be aware of the overall lighting and use the VF (and AE Lock button) to isolate the appropriate area for metering excluding very bright or very dark areas which are not part of the subject. Apart from when using a Macro lens or Tubes, I really can't think of an accasion when 3 EV compensation was not sufficient.[/QUOTE
    I have a hard time shooting birds with bright sky behind them. I understand what you are saying. I use my histogram to help keep me where I need to be. I think that is the most important thing to remember to check and correct.
  3. #23
    Small birds, bright sky, a situation where you can't meter selectively. So it's experience with a bit of educated guesswork.
    For this one I compensated by +1 EV.
    After the event I wish I had gone for +1.5EV but the moment had passed. Still it didn't need the +3 available.
    Attachment 50517
  4. #24
    Chicago, IL USA
    Quote Originally Posted by Peekayoh View Post
    Attachment 50517
    Does the Sony have spot metering, or center-weighted metering? You can use that on your subject to get proper metering. You probably wouldn't need all that exposure compensation with those different metering modes.
    Nikon D300 | MB-D10 | Nikkor 12-24/4 | Nikkor 50/1.8 | Nikkor 70-200/2.8 VRI | Sigma 18-50/2.8 | SB-800 | SB-80DX (x4) | Radiopopper JrX Studio |
  5. #25
    Yes it does have Spot, Center Weighted and Matrix.
    Yes, it was spot metered, but small birds at distance occupying a small part of the frame; you still need to give the meter a helping hand.
  7. #27
    Raleigh, NC, USA
    I think Frank makes a good point, although for a limited case. If that bird gets a hair out of the spot while you are tracking it, your exposure is going to shift. I can see manual being useful in that case. Ideally you would get them in the spot, lock exposure, then continue.
    Jason Hamilton
    Selective Frame
    Mamiya C220 - 80mm f/2.8
    Gear List flickr
  8. #28
    Quote Originally Posted by laydros View Post
    Jason
    What I do is take a shot in A mode then see where I am on the exposure then switch to M and compensate to get the right exposure so it don't change while I am shooting that bird.
  9. #29
    Interesting solution Frank. Try this...
    In (A) mode aim the camera at the subject,
    Press the AEL button to hold the exposure and then
    Use the exposure compensation button to adjust exposure.
    I find it helps to have the AEL button in "Toggle" mode.
