Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 49
  1. #11
    If you're going Hoya then Hoya SMC will do most things. For time exposures you'll need to remove them or use Hoya Digital Multicoated.
  2. #12
    I use a UV (0) filter on all my lenses, mostly Hoya SMC's a couple of tiffens, Hoya CPL. Mostly for my own peace of mind, and hoped for protection. Hoya seems to be the best quality / value filter and CPL. Hoya also makes a "clear glass" element protective filter, guess it really isn't a filter. In therory I would say the bigger the diameter lens go for the higher quality filter and that would mean higher cost, but would/should be more precision optical glass and coatings therefore less if any effect on the lens?
    Quote Originally Posted by seanhoxx View Post
    I'd suggest always a UV filter is better than a skylight (clear glass). Always though look for SMC or digital multi-coated. Single coated, uncoated and ordinary multicoated will be horrible on a digital camera.
  4. #14
    Livin in a redneck paradise
    As of two days ago I am revamping my filter line by converting all my lenses to 72mm through adapters, this is the largest size lens element I anticipate using. That will allow me to get by with just three filters, thus saving money, while still allowing higher quality filters than otherwise. I will sell off my other filters of various sizes. The three I will be using are: B&W Kaesemann Coated Circular Polarizer (because it was cheaper than the standard Hoya HMC for some reason), Tiffen 0.6 Neutral Density Graduated Multicoated (I recently had need of one and will need it more in the future), and the cheapest Tiffen UV filter I could get hold of.
    I would be interested in protecting my expensive lenses. I think that lenses are worth protecting with permanent UV filters if they are worth 10 times the cost of the UV filter or more, bearing in mind that anything less than a very good filter will not be worth it, even if just from flare. So, depending on the person and lens, $500-$1000 lenses are to me worth protecting. Your lens already has about 20 elements, one more perfectly flat high quality one should be OK.
    However, I don't think my own lenses are expensive enough to justify a permanent filter expensive enough to not hurt IQ. I got the tiffen for use in situations where damage to the lens seems likely: blowing sand, a breeze off an acidic hotspring or geyser, flying hard particles, etc. I figured no sense putting good money in a filter whose purpose is to take a beating be replaced after a few dozen uses.
    Keep in mind glass is harder than steel, and these lenses have special coatings so they are probably even harder than normal. There are almost no materials on earth besides a few precious and semi-precious gems that could scratch one. Chipping or dropping could be a concern, but flying snow and sea spray don't seem like issues to me. I have put my lens through quite severe treatment a few times when the cap fell of in my backpack while I was running down hills. The cap is badly scratched, but the lens has no damage whatsoever, from whatever angle or light I look at it.
  5. #15
    Georgetown, KY
    Quote Originally Posted by jedinite View Post
    Ok, so if I want to protect my $1700 lens from the elements when I'm taking sports shots (snowboarding or surfing) what would you recommend? Even when you're standing 100 yards from the ocean you still get an sea mist on stuff. And in the mountains, I want to protect my lens from blowing snow.
    I'm not really using the UV filter for anything but protecting my lens or at the very least keep it clean. If there's another type of filter you'd recommend let me know.
    I also use Photoshop for post-production effects and filters so I guess I could skip out on a lot of the creative filters.
    My primary lens is a Canon ef24-70 f2.8L and it has never had a filter of any sort on it. However, it does always have the lens hood. A hood may minimize the snow, surf, etc. and with/without a hood the mist is going to mess up the filter as well. As long as care is taken it shouldn't be a problem when you clean either the lens or filter. Now, if you're shooting a motorcross or similar where there may be chunks of mud, dirt, whatever coming in contact I would probably spring for a UV, just mist tho then no. "If" my front element ever does get scratched to affect its performance a trip to the Canon repair shop will be in order and the cost will probably be less than a quality UV.
    This has been discussed many times in many different forums. Some choose to use a UV for protection, I don't. Whichever you decide is fine with me.
    Dennis
    Canon 5D
    Canon 20D
    Georgetown, KY Photographer
    Retouching
  6. #16
    Sep 2008
    Is there any real benefit in having UV attenuated with a digital AF camera? Are AF sensors weighted for decreased sensitivity for that part of the spectrum?
    I notice that all the DSLRs I've read up on in deciding to jump into the realm of DSLR last week had IR filters just in front of the sensor. I remember years back when I was playing with 35 SLR that it was possible to get very pleasing skin tone from film sensitized to IR frequencies. Is there an option in the DSLR arena for working with that end of the spectrum?
    Lots of questions for a beginner.
  7. #17
    Jul 2008
    Quote Originally Posted by D Thompson View Post
    Thanks Dennis, your response seems to be very much applicable to the exact lens I'll be using primarily. I may hold on the filter but what is your experience cleaning the lens after a day of shooting in the elements. Is it something that is quiet easy to do a good job of?
    I will be picking up a lens hood, I just thought having a filter is a good way of protecting my investment. I guess you guys are right, glass is one of the hardest substances on earth, it would be quiet difficult to scratch it unless I were cleaning it improperly or were in really harsh conditions (blowing sand, dirt, mud etc.) And even if I picked up a good UV filter unless it was glass it would probably be damaged. I'll have to check out what is available in the camera store I'm going to be purchasing my camera at. I just don't want to be attacked with a bunch of high margin accessories (if filters are considered high margin) from a sales person, without knowing what I really need with my camera.
  8. #18
    Lots of people buy what they don't need after talking with the salesman. Be careful. The L lens should come with a hood (not positive on that). I would say if crap is flying through the air then I'd have something protecting the front of my lens. The hood will protect it from every day stuff. Use it even indoors. At the beach where there's salt in the air, I usually have a CPL on anyway because it lifts reflections off the water and darkens the sky. Mist is a pain because it gets all over everything and it's hard to avoid.
    As far as cleaning goes, I usually do it in 3 steps. First I use an air blower to remove what I can w/o touching the lens. Then I use a brush. Then a lens pen or lens cloth. The goal is to avoid rubbing anything hard that may have collected on the lens into the glass. Also to avoid getting crap in my pen or cloth that might scratch the lens during a later cleaning.
    Georgetown, KY
    As far as cleaning the lens Lukas gave good advice. Like him, I'll first use a blower, followed by soft brush if necessary, and then a lens cloth. Sometimes I'll give it just a little breath before I use the cloth. Light pressure in a circular motion.
    Both of those lenses you mentioned should come with a lens hood and I do keep a hood on every lens I own. I'm also fairly anal about keeping the lens cap on if I'm not going to be shooting for a few minutes. Yes, I've forgotten and raised the 20D to my eye and wondered why the hell everything is black . Exercise care and judgment and you should be fine. Like I said, if you're shooting a dirt track or similar then I'd probably invest in a good UV for protection.
    Dennis
    Canon 5D
    Canon 20D
    Retouching
  10. #20
    Exclamation Fujifilm IS Pro
    Quote Originally Posted by stanj View Post
    Fujifilm released a new version of their DSLR camera called the IS Pro (<- Click on this), which is specifically designed for IR/UV photography with an enhanced sensor which acts like film. You still have to use the specialized filters for this type of photography, but THIS is that camera you ask about.
    Attachment 40859
    It's not cheap ... and the special filters are just about as much ... but WHAT A CAMERA!
