    EOS Utility problem
    EOS utility will not recognize my new EOS XSi. Even after downloading the latest version from the Canon website, it still will not see the camera, though Windows Photo gallery has no problem with it. Canon support suggested unplugging any printers and scanners (of which i had none) which my conflict with it and restarting WIA. This still did not solve the problem.
    Did you uninstall-reinstall? My XSi gets a little flaky from time to time also
    my photos on flickr
    i don't know if it's the same problem, but when i first got my 40d up and running on my computer, EOS utility would not happen
    it didn't even install off the cd
    so i had to manually open and explore the cd, and i created a shortcut to the .exe file and manually install it like that (or something)
    now i click on the shortcut, eos utility opens, plug the camera in and turn it on, and it works like normal
    not sure if that helped any, but it's there if you need it
    Canon Powershot S3 IS
    Flickr - blentley
    CSC
    I've re-installed the software twice and still no luck. It will open from the shortcut but everything except the "monitor folder" is greyed out.
    On another note...tried my hand at nighttime shooting after the Germany-Turkey Soccer game tonight. Over two hundred shots and only 10 or so really came out decent! I have alot to learn.
