Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
    Canon xsi - not focusing in low light..
    I'm having a issue with the camera focusing in low light. I tried similar shots with my Canon SD850 IS and it seems to focus the shots.. I'm confused.. I'm using the kit lens on program mode, without the flash.. thanks for your help.
    if the xsi is anthing like the xti, it doesnt have an AF assist lamp. you need to raise the flash which acts as your AF assist in low light.
    Yep....what Rooz said.
    You may need a "faster" lens than the kit lens.....or use the "strobe" light that the built-in flash can provide.
    Canon 5D MKlll & Canon 50D
    Canon 70-200mm f/2.8L USM | Canon EF-S 17-55mm f/2.8 IS USM | Canon EF-S 10-22mm f/3.5-4.5 USM | Canon 100mm f/2.8 USM Macro | Canon 70-300mm f/4-5.6 IS USM | Canon 50mm f/1.8 | Sigma 17-70mm f/2.8-4.5 | Canon 430EX Flash | Lowepro Mini Trekker AW | Lowepro Toploader 65 AW | Lowepro Slingshot 200AW | Kata 3n1-10
    Panasonic Lumix FZ200
    Panasonic Lumix TZ7 (aka ZS3)
    Panasonic Lumix FT3 (aka TS3)
    Ali Baba.....the Thief of Bad Gags
    Los Angeles, CA
    Or you can use a Canon Speedlite which has the option for infrared (well not really since you can see it but it looks red to the eye) focus assist, which is way less intense than the seizure-inducing strobe effect of the on-camera flash assist mode...
    Canon A720 IS, 40D w/ BG-E2N, 28 1.8, 50 1.4, Sigma 70 2.8 macro, 17-40 F4 L, 24-105 F4 L IS, 70-200 F4 L IS, 430 EX, Kenko 2X TC & Ext Tubes, AB strobes and more...
    View my photo galleries here: imageevent.com/24peter
    Or you can go old skool with a D30 or D60, both of which have a proper assist lamp.
    Ouch.
    NYC
    Or, you could change your handle to something less obnoxious than "PhotoMaster".
    Some Gear: Nikon D700; Nikkor AF-S 50 f/1.4 G; Nikkor AF-S 24-85 3.f/5-4.5 G ED; Tamron 28-300 f/3.5-6.3 VC; Nikon SB-800; Velbon Maxi-F; Canon Pixma Pro 9000; Canon S3IS, Canon SD500; Epson 4990; Epson P5000; Wacom Intuos 3
    Main Software: Capture NX2; Adobe PhotoShop CS2; Corel Paintshop Pro X2 Ultimate
    Sold: Canon XT/350D, EF 24-105mm f/4 L IS, EF 100mm f/2.8 Macro; EF-S 10-22mm f/3.5-4.5, Sigma 18-200 OS; Canon ET EF 25II; Kenko Pro 300 DG, Canon 430EX, Canon BG-E3.
    Or we could swap camera's as mine has 'built in' low light sensor (after market mods)....
    Quote Originally Posted by 24Peter View Post
    Best option....although, using this option (and the option of internal strobe), means you will be taking a "flash" shot....which may not be what you are after.
    In the case of the internal strobe option (no cost), the strobe attracts too much attention and you lose any candid opportunities.
    At least with the external flash (cost), the infrared is a little more subtle.
    Hmm... Didn't think it was a great lot better than the XT
    Quote Originally Posted by Honest Gaza View Post
    You can set the flash not to fire while still lighting up the AF-assist beam in Custom Functions on the camera body.
    Ouch.
