    pinkcougar@aol.com Guest
    Question nikon d50 card problem
    i have a nikon d50 with a scandisk ultra 2.0gb photo card. it has 800 pics possible- i used 700+ and no problems- went to walgreens photo booth- stuck card in wrong slot-which i have done before- but this time- card not reading and now camera says this card can not be used-also camera says cha- please help with any advice- has all pics from birth- to 2 1/2 year old son- any suggestions
    Quote Originally Posted by pinkcougar@aol.com View Post
    have you tried to use a card reader? this happened to me before on my old canon powershot, the camera said that the card is corrupted. I used my laptop to check the card and i was able to retrieve the all the photos in it. you also might want to try rescuepro or photo rescue.good luck!
    "Conform but always be yourself."
    Nikon D300
    Nikon AF-S VR 18-200mm
    Nikon AF-S VR 70-300mm
    SB-800
    SB-20 with optical slave trigger
    Tamron SP AF28-105mm F/2.8 LD
    Vivitar Series 1 (AI-S) 28-105mm F/2.8-3.8 Macro
    Super Cosina 100-500mm f5.6-f8 MC Macro
    Tripods:
    BOGEN 3021 with Cullman Ballhead
    Gitzo Tatalux
    Leitz Tiltall
    BlackRapid RS-2 strap
    http://www.flickr.com/photos/nikx/
    is the lock on?
    i actually did this once- i was using two cameras and one card switching back and forth- and in the process, turned the lock/hold on. check and see if that is the case.
    if not, take a look at the contacts- are they damaged? if they are broken, the card is gone forever anyways- try plugging it into a card reader and see if it works then
    hope that helps
    Nikon D50...Awesome DSLR
    -SLR Equpiment: 18-70mm, 55-200mm, and 14mm prime
    Nikon L12- just died, sent in for repair, no idea when it will get back
    A large chunk of Gondwana
    Check the write protect switch on the side of the card then download some disc recovery software (there is plenty available on the net) and use a card reader on your PC to access the card. The SD card is exactly the same as a hard drive as far as the software is concerned, it's just a device with data on it.
    If that does not work it may be that by putting the card in the wrong slot you have zapped it and destroyed it.
    Sorry but the moral is to back up regularly don't leave precious data anywhere where it can be lost or destroyed instantly.
