Thread: sd card problem
    dmmmjm Guest
    sd card problem
    Hi,
    I have a 1gb sd card with photos on it.
    It all worked fine until today when I would not read it properly.
    The memory section is saying the correct useage and when i put it in my card reader 7 folders come up which i can not access. (or delete them)
    Folders include:
    develop.men
    itn
    logas Di.rec
    r Centre. -
    re - 015.26
    82 80750.6
    So i have a card 4/5 full which i can not access or delete!
    Can anyone help
    Newton ,Massachusetts
    If this is the first time you have put this much data on the card, you may have a problem that I had. The card reader could not read beyond a certain amount of data. Try and connect your camera via USB to your computer and see if that will work.
    Good luck
    Panasonic FZ20, Kodak DC4800, Canon SD850 for when I don't want to carry a camera
    http://JLVACCARO.4T.COM
    I have heard that some readers have problems with more than 512MB on card. (I heard about xd card readers though)
    I would also recommend to use the camera as a reader.
    regards
    F10
    Singapore, Yishun
    Are your hard disk or system requirement be compatible with the SD card?
    Are you buying a fake brand with an unknown manufacturer?
    - Nikon D40
    - AF-S DX Zoom-Nikkor 18-55mm f/3.5-5.6G ED II Kit Lens
    - 2 pieces of Kingston 1GB SD cards
