Results 1 to 10 of 12
    Is it possible to use Raynox DCR-250 with 18mm-55mm lens kit or 50mm f1.8 lens?
    Hi,
    I have a question that whether we can mount the Raynox DCR-250 macro lens with the 18mm-55mm lens kit or 50mm f1.8 lens to make a macro lens? If possible, how about the performance? The macro lens for a DSLR is so expensive.
    The DCR-250 is able to mount with lens which filter thread is from 52 - 67mm, but I mostly see it is mounted with P&S camera.
    Thanks for reading my dummy question.
    ________
    hotels in mexico
    Info taken from Raynox site:
    DCR-250 Super Macro/Close-Up lens
    You can simply "Snap On" DCR-250 Super Macro lens onto the lens filter threads.(52-67mm) and it will be able to take macro images with minimum distortion.
    ( Use manual focus mode while the lens is attached.)
    Magnification : 2.3X compare to 18-55mm macro image size.
    Lens construction : 2G/3E Optical coated glass elements.
    Front filter size : 49mm
    Rear threads size : 43mm
    Size/Weight : DCR-250 53x18mm/60g.
    CAMERA STAND KS-2000 FOR MACRO IMAGING
    http://raynox.co.jp/english/dcr/dcr2...exdcr250eg.htm
    I have a the Raynox 250 and I use it on my Canon S1 IS and get great results. Here is a picture of a Canadian twenty dollar bill. I circled the area that I zoomed in on.
    Dodo,
    Interesting, could you let me know if you are able to get this to work?
    I own a Canon 400D myself, wouldnt mind to try out a more economical version for macro shots.
    Krz
    How much does this cost?
    Krz... macro extension tubes might be the best solution.
    is a 50mm macro out of the question?
    maybe a sigma 28mm macro f2.8?
    Canon addict
    Quote Originally Posted by Rhys View Post
    Ryhs, besids this brand, which other brands would you recommend for macro extension tubes for my Canon 400D 18-55mm kit lens?
    I just wanna to achieve some kinds of these photos:
    [Source: http://www.vnphoto.net/forums/showthread.php?t=5165]
    The author used Panasonic FZ20 + DCR-250 and his techniques
    I wonder whether when we mount DCR-250 to 18-55mm lens then we can get similar quality (of course I need to practice more)?
    I'm still undecided between S3 IS and an DSLR. Each has its pros and cons.
    ________
    Ranchero Rio Grande
    Absolutely wonderful!
    Im still wondering how much and if I could use this with my Canon 400D to achieve such shots.
    Krz
    the lens DCR-250 itself is just around 45$ including shipping and tax (if applicable).
    http://www.bhphotovideo.com/bnh/cont....x=0&image.y=0
    www.lensmateonline.com
    www.bugeyedigital.com
    Raynox has sample images captured by Canon 300D and DCR-250
    I would think that other brands(Pentax, Canon, Nikon) and 18-55mm lens could achieve the same
    Actually, I dont live in the US, otherwise I will give it a try
    ________
    ultimate fighter
